RS-MMC (reduced size)
8 replies · 2,656 views · Started 07 January 2005
Do any of you guyz know if higher capacity multimedia cards say 128mb, 256mb or 512mb is available for 7610 cos the 64mb is too small. Besides do u know the size of the max mmc it can take
I know you can get 128, 256 and 512Mb cards. I am currently using a 512Mb card. Got it for about �45 on eBay about two months ago. I have seen 1gb cards advertised as well.
You can also get the slim Nokia battery and use a MMC card which is far cheaper and actually usable by other devices (like almost any device that accepts SD). Also you can alter your phone to accept MMC with teh standard battery. Do a google search, as I no longer have the link demonstrating this.
