what if i make a new contact and didn't put anything in it,
would it also be added to my memory??
i have a question about the contacts
According to my knowledge, it'll not be added into your memory if you didn't enter anything.
ic, thanks, by the way, do u know whats dis error report??
app. closed
mediaserver
e32user-cbase 33
thnks 😊
[quote="sad1k981"]ic, thanks, by the way, do u know whats dis error report??
app. closed
mediaserver
e32user-cbase 33
thnks 😊[/quote]
Hmmm. i've no idea. Maybe any folks out there does? 😊
has anyone ever noticed a change in the contact memory,for example when i scan my memory on my 7650 it can show 400kb for the contact memory and the next day it can show 320kb and it keeps on changing all the time and that is without adding or removing some contact has anyone ever noticed this before???Try it you will be shocked
[quote="john74"]has anyone ever noticed a change in the contact memory,for example when i scan my memory on my 7650 it can show 400kb for the contact memory and the next day it can show 320kb and it keeps on changing all the time and that is without adding or removing some contact has anyone ever noticed this before???Try it you will be shocked[/quote]
Hmm.. I guess that this should be a temporary memory stored on your user memory area. It'll be cleared at some time cycle.
Other folks out there, have i answered this wrongly? 😊
Yes quite! There are some thread in this forum that already explain this! The contacts compress themsleves after a while! If you add a new contact the memory can increase significantly! however if you delete it then you will have to wait for the contact to be compressed again! After a week or so without any contacts added or deleted they are compress to the minimum size!
Hey
"i2umi"
your avatar is that the building near the suntec city ???
[quote="Pichu"]Hey
"i2umi"
your avatar is that the building near the suntec city ???[/quote]
Yeap, its the Esplanade.
ic....
well thnks for the reply,
