QuodRings - ogg music player and ringtones
3 replies · 12,552 views · Started 08 January 2005
QuodRings is an Ogg music player with a twist. It allows you to use your music files as ringtones. You can set general ringtones as well as well as custom tones for individuals in your address book. The program currently supports only ogg vorbis files, but it does have an extensible plug in architecture which will allow more formats to be added in the future.
Author's Notes:
QuodRings is a practical music player application for your smart phone, you can use it to conveniently carry and listen to your music files everywhere you go! But QuodRings is more than a common music player as it allows you to use your music files as ring tones.
Main features :
- Currently QuodRings supports the Ogg Vorbis format for the music files
- Default music can be defined to play when someone calls.
- Allows the definition of different music�s to act as ring tones for the different people in your phone list ( ex: you can define your husband/wife�s music, your friend�s music, etc?).
- User-friendly interface similar to common series 60 applications, you won�t have to learn a new interface to use it.
- Music files can be stored anywhere in your phone default memory or extended memory card.
- Highly optimized search algorithm allows easy localization of music files in your mailbox or anywhere else on the phone memory.
- Can easily share music files with other applications as it doesn�t require them to be on a specific location.
- Extended utilities like available memory information or file details & delete capabilities.
- Native C++ Symbian OS application that can Installed in a small 80 K file.
- Advanced plug-in architecture will allow more formats to be added in the future.
This application is still on BETA, please report any problem using the support address and check our web site for more info : www.quodsoftware.com
Rafe wrote:QuodRings is an Ogg music player with a twist. It allows you to use your music files as ringtones. You can set general ringtones as well as well as custom tones for individuals in your address book. The program currently supports only ogg vorbis files, but it does have an extensible plug in architecture which will allow more formats to be added in the future.
Author's Notes:
Main features :
thx i was searching 4 this 😃
