Nokia 6600 Movie Player?
4 replies · 2,805 views · Started 08 January 2005
can any1 tell mi which is the best movie converter and player for Nokia 6600,and what size sud b my memory card to store 2 movies of abt 100 minutes each?i want to convert dvd as well as normal moives too those frm vcds or those stored in my comp.
a movie comes out at anything between 40mb-60mb so you'll need a decent sized card to store em.as for the software i dunno ne good programs so i'd just search google n c wot comes up
oh yeah theres a program on my-symbian that can read dvd copied movies and uses the whole screen so you might wanna check that out.think its called dvdmobile or something like that but 1 bad thing.the files come out MUCH bigger
hellraiza15 wrote:oh yeah theres a program on my-symbian that can read dvd copied movies and uses the whole screen so you might wanna check that out.think its called dvdmobile or something like that but 1 bad thing.the files come out MUCH bigger
i think you mean dvd to nokia?
