6630 email setup
2 replies · 6,778 views · Started 08 January 2005
I have a 6630 and I want setup the email to acess one email account that don't permit GPRS acess.Must be GSM or CSD.The problem is that my Vodafone 6630 only have GPRS as data bearer.Can anyone help me?
camomopa wrote:I have a 6630 and I want setup the email to acess one email account that don't permit GPRS acess.Must be GSM or CSD.The problem is that my Vodafone 6630 only have GPRS as data bearer.Can anyone help me?
iam afraid that it will be not possible... This device is not supporting CSD,or HSCSD,only GPRS,EDGE,or W-CDMA... 😃 you can only acess those e-mail accounts,where GPRS acess is possible... and your problem is not caused by Vodafone,the SIM free unbranded device is the same,not supporting CSD... but if you are in Vodafone country,than try to use 3G services.../if they are available at the moment/ 😃
Are you unable to access your email for sending or receiving?
Most ISP email accounts will only let you SEND mail thru their server if you are using them as your ISP - therefore your GPRS wont work as they want you to dialup into them, which is why you need GSM.
You may find you can still collect youre-mail from them via gprs/3g thuo.
In which case you should configure you e-maill account on your 6630 to fetch mail from your ISP e-mail account and SEND mail thru your mobile operators mail server - most will have a mail server you can send mail thru.
Hope this helps
Will
