I don't think that you cn delete only one number from the list..
But u can use some thrid party software and the number would not be visible in logs..
You can just press 'c' to delete individual log entrys cant you?
elton wrote:You can just press 'c' to delete individual log entrys cant you?
You can Delete Number From Dialed, Recived, Missed. But when you go the All Communication Detail Then u have the only Option to Clear Log. And when you Press "c" Button Nohing happenes.
I tried on Nokia 6600, 7610, 6630 rest don't know.
Oh ok vicky,
Im sure i used to be able to on my 6600,i haven't got one anymore tho so i cant check.
I see you didnt change your name in the end then 😊
[CENTER]Hi Vicky
Can you till me about thrid party software , that make number would not be visible in logs & where can i find it
Thanks alots
[/CENTER]
