Changing fonts with 7610
2 replies · 2,885 views · Started 08 January 2005
I have read on many other forums on the possibility of changing fonts on a series 60 like Nokia 7610.
However, the method that they had worked with firmwares before 4.0441.0ch 08-10-04. Does anyone of you here have a method that works with this firmware?
I would really like to know that there's one because I prefer other fonts than the default one.
Regards,
shox
😊 yeah it's possible...i have these font's installed on my fone....you can go to zedge website and download, or, if you want, inbox me your email and i will send the app to you asap... one of the font's..tahoma is more or less the same as the normal font, so you may do well not to install it...but like i said, if you want, inbox me your email, and i'll send it...regards jay. 😃
shokkuweibu wrote:I have read on many other forums on the possibility of changing fonts on a series 60 like Nokia 7610.
Regards,
shox
You don't have find anything
Here is the Link Which can give you each and everything abt changing Font on Symbian Series 60 Phones.
I am Personally using then so you can Try.
Thread Closed.
