First when I turn my phone on it automatically connects to the internet, how can I stop this from happening. Then my libs folder became corrupt and unreadable for no reason, then my video clips folder copies its self to make two of the same folders both called video clips but now there is file in both folders called � but it come up as << �.�ŏ on the phone and I cant open or delete it. And now my real player won�t retrieve sound clips from the memory card.
can someone please help thanks
I am having a lot of problems with my 6260 phone can someone help
supaman wrote:First when I turn my phone on it automatically connects to the internet, how can I stop this from happening. Then my libs folder became corrupt and unreadable for no reason, then my video clips folder copies its self to make two of the same folders both called video clips but now there is file in both folders called � but it come up as << �.�ŏ on the phone and I cant open or delete it. And now my real player won�t retrieve sound clips from the memory card.
Try to format your phone.. use google or the search feature of this website to find the right code. You may also want to ask Nokia regarding this. Your problem is not normal. My phone is not behaving like that. Gud luck!
