midi files - a question
2 replies · 2,373 views · Started 19 October 2002
hi ..
i just got some midi files and sent them thru IR to the phone. i saved them, (from inbox).. and instead of them going to C:/Nokia/Sounds/Digital.. as it did before i got SeleQ.. now they end up in C:/system/sounds/digital..
so if i do try and cut/paste them over to C:/Nokia/Sounds/Digital, i'm get a warning " .. delete system files ".
what should i do about this? do i just go and cut/paste? (and why don't they get copied to C:/Nokia/Sounds/Digital?)
thanks very much for your help on this :-?
Hi
Not sure why yours goes into the Digital directory.
You can cut and paste from the mail to the desire directory.
Just ignore the warning.
thanks a heap!
yeah... just worried cos didn't wanna mess too much with the system files.. causes lots of problems if something does go wrong.
