Thinking of buying a SENDO X. Would be synchronising with Outlook 2002. Have a contacts database of 3000. Would the Sendo X cope with this volume?
Thank you
Thank you
Guy Mitchell wrote:Thinking of buying a SENDO X. Would be synchronising with Outlook 2002. Have a contacts database of 3000. Would the Sendo X cope with this volume?Thank you
I have around 1000. Takes a while to load (esp. with voice activation) but it works fine....
J.
We've tested up to 5000 contacts, without issue. The initial synchronisation will take a while (as it does all of them), but subsequent sync's will be quicker (just does the new/changed records).
Hope this helps!
pk
