Hi Guy's
I have P900, and i want to reinstall the OS on it.
Can you please tell me how to do it ? and what do i need ?
Thaks.
Bara'
Hi Guy's
Thaks.
Bara'
I don't think that's possible
I Don't Think It's Possible But If there is any Problem you want to solve , You Can Try to Format It !
To get to internal menu and format option:
Close the flip (virtual flip may work) and using the JOGDIAL and star key from the main screen (with operator name showing)
Up, Star, Down, Down, Star, Down, Star
Format is under option 3 (Service functions) - When you do this it'll say about filesystem has been corrupted and it's reformatting. That's quite normal. Don't panic. (Of course it'll wipe everything on the phone, but it comes back with the factory defaults in it)
Hope That Will Help you !
