mms 100kb ristriction
5 replies · 2,129 views · Started 09 January 2005
hello to all 😊 can anyone pls tell how can i send pictures or videos wich are more than 100kb as mms
and
how can i mms .SIS files.
how can i infrared .sis files
pls dont tell to serch i have serched but failed 😊
The 100kb mms limit is set by the operator,so you cant do anything about that.
Sis files are protected from being sent by the firmware.
elton wrote:The 100kb mms limit is set by the operator,so you cant do anything about that.
thx elton god bless 😊
dunno bout da firmware protection but i know another way
1.install 'file explorer' on your fone
2.using a pc & mmc writer copy and paste the .sis file onto your mmc card
3.open file explorer and locate the file
4.press 'options' then 'send' and you get 5 options of how to send it
still doesnt work, but you can send them by renaming them to 'filename.si' and the recieving phone can still install it without renaming back to the original extention (.sis) 😊
EDIT: im on about files send via infrared or bluetooth, not mms 😊
well the 100kb limit is set by nokia itself i guess because in my country my operator only allows 64kb mms not even 100 😞 i guess u can also send .sis files by the freeware called forward, it lets u send the files that r in ur inbox, send the .sis file to ur phone, select it via forward and then select send via mms, it should work although i havent tried it. Also, do a search on that on the forum, i think u will most definitely find an answer as i remember reading another thread about it.. hope i've helped u out 😊
