I've been using dBpowerAMP Converter but as it seems its MP3 encoder is a trial version and after 30 days can not be used anymore.
I was using this application to set my mp3s to mono, 40kbps, using 16000hz sampling but now it's not working anymore. :frown:
What do you suggest me to do?
medasa why do u post the same thing again and again? either create a new thread or reply in the one thats related to what u want to post which is better.. a moderator might not like this..
zainman wrote:medasa why do u post the same thing again and again? either create a new thread or reply in the one thats related to what u want to post which is better.. a moderator might not like this..
First of all, I'm afraid to say that you're not supposed to tell me what to do here! If I'm doing something wrong, a moderator will definitely warn me! So don't worry about it!
Secondly, the problem I encountered with dBpowerAMP doesn't seem to be that much complicated! Either one may suggest an alternative application or there should be another approach with the same dBpowerAMP.
FYI, I posted a reply to that sticky thread one week ago; As I didn't receive any reply, I just started a new thread which may more easily come to attention of visitors.
