obex file delete problem
1 replies · 3,078 views · Started 10 January 2005
hi all,
i'm able transfer files from my pc to my 6260 with eopx usb dongle using obex file transfer. transferred files stay at obex file transfer window. when i want to delete one of the transferred file, it generates an "incorrect permissions" error. even though, i can't find the files with a phone file explorer
i couldn't find anything to set permissions. can you help me at least by telling where the hell are these files stored?
ok, still not found how to set permissions but figured out another way.
transferred files over bluetooth are stored at c:\system\mail. search through the folder for the transferred file and delete it. that means when you transfer the file, it is stored in your message inbox. deleting the message will also be helpful.
