Changing alarm on 7650 with World clock pro
3 replies · 3,896 views · Started 19 October 2002
guys i have installed the World Clock pro program and it says that you can change the Alarm on your 7650 (alarm clock sound),i just cant manage to change it no matter what it goes back to the same old crappy 7650 alarm!!!!Anyone facing the same problems??
I read before that the alarm seems to be in the Read only memory portion of the phone, and you can't change it, cause if you want to change the file "whatever.alarm" to something else by the same name you have to replace it, but you can't cause its read only. Someone long ago posted that he did succeed in doing so with SeleQ but it has'nt been confirmed, I tried but no cigar! 😊
it not works at this beta....
but if u load down e-profile prof.(the new beta,the last link down on the side)
from here:
http://www.psiloc.com/nokia/eng/eprofiles7650/index.html
u have
A:more memory,
B:real nice progy with the working alarm feature
(Remove first inside world-clock pro all the alarms u set up.(Calendar are not importent)
set back the Alarm to phones settings,
then deinstall it like this:
first:alarm-enha.
then world-clock
and if u have no other prog.from psiLOC on your phone:
PsiNT-eLib.(what will remove from self also the PsiNT helper.
it will ask u allways,if u really wanna remove it,and that maybe other prog.not will work if remove.This is first time a prog.from psiloc ask this:normaly it removes the help-adds.from self:maybe because the beta-version?)
Then install e-profiles.
This all is at your own garanty,
because its find out in privat investigations
(cause i had a lot of troubel,if i try to remove it:the alarm-enha.want dissapear with the "normal way":wC/psint lib/helper/alarm)
for more questions to psiloc direkt,
i open a thread here:
http://www.allabouter6.com/phpBB2/viewtopic.php?t=3379
S�mi
