that indicates which cellular system the phone is currently using?
it currently reads T- Mobile
N3660
what software should i look into?
sorry for the stupid question
N3660
That banner is often refered to as LOGO. U can use fexplore a freeware program to select a logo then use it as ur phones logo. Search this site for some free logos and fexplore as well. Installing fexplore is a different issue though u can manually change the logo (still using fexplore) as discussed in many threads in this forum. Just not sure if a conflict in changing logos applies to your operators configuration as sometimes the operator has built it in so that you wont be able to change it.
Cheers.
Kamalayan wrote:That banner is often refered to as LOGO. U can use fexplore a freeware program to select a logo then use it as ur phones logo. Search this site for some free logos and fexplore as well. Installing fexplore is a different issue though u can manually change the logo (still using fexplore) as discussed in many threads in this forum. Just not sure if a conflict in changing logos applies to your operators configuration as sometimes the operator has built it in so that you wont be able to change it.Cheers.
easy as pie.. now ill see if i can change the intro 😊
thanks for helping a n00b!
I dont think its possible yet. Or if it is,i hope it wont result to the four blink or 2 blink problem. Caution funk guy 😃
dummy file maybe?
just got my phone today, im still looking in to it 😊
funkadelik wrote:dummy file maybe?just got my phone today, im still looking in to it 😊
