right, where do i start?
I recently bought tomtom mobile for my nokia 6600, and i am having a few problems, someone please help me!!!!!! :con?
Basically, tomtom mobile came with a 128mb sd card with the program and maps already installed onto it.
I am currently using a 256mb MMC card and do not want to lose all my files on it. so i want to transfer the tomtom mobile files on the sd card onto my current memory card.
sounds easy? NO!
firstly, i connected my phone with the tomtom card inside onto my pc, used pc suite and transferred all the contents onto the pc. then from the pc i transferred it onto my own mmc card. but this did not work!!!!! 😡
so i used FExplorer and looked through all the files on the tomtom card to see what i had missing, copied them and transferred it onto my own memory card.
Right, this kind of worked, as i can load up the tomtom program now but the screen is blank with the message 'no maps found' or something written accoss.
WHAT DO I DO?!?!? SOMEONE PLEASE HELP ME!!!!!!!!!!!!! :frown:
im pretty certain most of the files on tomtom are on my card.
much aprreciated.
or can someone just tell me how to do it easily with no hassle so i can use tomtom mobile on my own memory card.
