My wife just got this device along with a CD full of JAR game files. We're both stumped as to how to get the games up onto the phone. I had a Moto T720 a while back on which I was able to upload JAR files from my PC through intermediary software obtained from the Moto site intended for field techs - it was a little fussy, but worked (mostly). Does the same apply to this Nokia? Is transfer software required, and if so what is it and where can I get it? Thanks in advance for any help sent my way!
.jar files on 3620
Once I posted this cry for help, "related topics" came up below the post explaining just how easy it is to do this - much more so than the T720!. This from Tatus:
30-07-2003, 07:28 PM
Tatus is Offline:
c(",) Join Date: Mar 2003
Send them to your phone using BT or infrared.. Then go to your inbox and open the message. It will prompt you, asking if it should install the program.. You may delete the message containing the file, in inbox after installing it 😊
Couldn't find it on the FAQ prior to posting though.....
