Full Screen View in Doc Viewer & London Underground Maps
2 replies · 3,417 views · Started 11 January 2005
Just wondered if the new fw release will feature a full screen view option in Doc Viewer? (like the option available when searching the net).
I've tried the doc viewer with a range of file formats. Simple word documents work fine, when you try a pdf such as the London Underground map (www.tfl.gov.uk), it locks up?? I've also tried the map as a jpg and gif and they both take ages to view and you can only view them in the small box which makes navigating difficult.
Incidently if anyone knows of a programme to view the London underground map then please let me know as I cant find anything on Vodafone (I know that Orange have developed one which is annoying)
Come on Sendo... us Vodafone users are waiting very patiently for all the lovely updates.
Thanks for the themes by the way.
Supposedly the Vodafone update will be released "Very soon" according to Sendo customer support 😊
MAJ25 wrote:Just wondered if the new fw release will feature a full screen view option in Doc Viewer? (like the option available when searching the net).
Not sure about a full-screen mode in DocViewer, but I will ask about it.
As for getting one of those tube maps onto the Sendo X I actually saved the JPG version into C:\Nokia\Images on the handset (via PC Connect), then used the PHOTO ALBUM viewer to see it, which has ZOOM, FULL SCREEN and, maybe more importantly, ROTATE mode, which is handy to get it into landscape for full-screen viewing.
If you really want Tube Maps, go here for a S60 application that does route planning, etc, and not just for the London Underground - handy for travellers:
http://www.visualit.co.uk/Series60/S60_tubelon.htm
