7650 i need answer, please help :)
6 replies · 2,032 views · Started 20 October 2002
i have loacl area network with internet conection and i have usb bluetooth, could i check my emails and other stuff in inernet VIA BLUETOOTH?
for example:
could i serf wap sites?
could i stream music?
check mails?
serfiN' web?
what do you think and if you'll say YES, how could i do that?
THANKS a lot!
Do you mean PC => Phone internet connection?
If what you meant is the above, i don't think its possible..
All i know is that you could only do Phone => PC internet connection through your phones GPRS, etc...
Any folks out there could correct me if i'm wrong? 😮ops:
I don't get it. You want to surf on the net using your phone? Connected by bluetooth to your PC that has an internet connection? Um... why don't you just surf on your PC then?
Or am I reading the question wrongly?
What he mean was can we use our phone as a modem to surf using Bluetooth connection to GPRS network.
No you can't. So far as much as i know and understand Nokia7650 only allow Bluetooth Serial Connection.That's mean only file transfer from phone to pc and pc to phone.
Correct me if i am incorrect.
If you mean can you use access the 'net on your phone over bluetooth to a LAN then no. The handset could in theory do this but it's not an option in the software (er, maybe firmware) because the networks want you to use expensive GPRS instead.
[quote="Edgedale"]What he mean was can we use our phone as a modem to surf using Bluetooth connection to GPRS network.
No you can't.[/quote]
Edgedale - you can, I've done this to connect to the 'net with my laptop. Pricey though.
Thanks for your information. 😉
[quote="CiaranMcNulty"][quote="Edgedale"]What he mean was can we use our phone as a modem to surf using Bluetooth connection to GPRS network.
Edgedale - you can, I've done this to connect to the 'net with my laptop. Pricey though.[/quote]
