I have an Unlocked A920 flashed to A925 and I was wondering how I would go about (or if it is even possible) To change the settings on the home screen so that they are not specific to the "3" network, as I am in Canada and not using that.
Thanks for the help.
Yes, possible.
A guy from Austria programmed a very nice software which runs on a PC (Windows). You can customize all three pictures, names and URLs of the home screen. Currently it's only in German, but not very hard to use/understand.
You have to have full access to your mobile's C: drive to exchange the modified files!
Search for A92xMENUv13 or A92xMENUv13.rar, you might find it somewhere for download.
the_geek wrote:Yes, possible.A guy from Austria programmed a very nice software which runs on a PC (Windows). You can customize all three pictures, names and URLs of the home screen. Currently it's only in German, but not very hard to use/understand.
do you have the software?
if so could you email it to me?
fone crzy wrote:do you have the software?
never mind. i got it. and its available in english. if anyone wants english or german PM me!
How do I should put changes in my phone? I create snack.ini and put it in c:/system/apps/now folder but after reboot I see the same settings as it was. :frown:
Also when I try to generate snack_now.sbm I see an error screen and program falls down... :con?
Please give me instructions how to use this program especially created snack.ini
Make sure you put the program in a folder on your root where it has a small file name. If there are long filenames/ones with spaces, apparently the MBM graphic file doesn't get created.
I moved my proggie to C:\A1000 and it works a treat.
I backed up snack.ini and then copied the snack.ini and snack.mbm file to System\Apps\Now. Rebooted and worls good!
Still looking for a way to use the three snack lines to make them point to an application on the phone instead of the internet with 3s walled garden approach.
Ive made the snack.ini file and it's saved on my computers C drive. When I open up MY A925 software and click on the A925 c drive, the only option is a documents folder. There is no systems folder. Please help expalin how to get the snack.ini file loaded on to the phone. Thanks
