Transferring SMS messages from T610 to 6600/6630?
2 replies · 2,294 views · Started 12 January 2005
I've just got a 6600 and 6630, and need to transfer all my SMS text messages from my old Sony Ericsson T610 to these two Series 60 devices.
I've backed up the messages from the T610 using Float's Mobile Agent into .CSV, .XML and .HTML files, and tried sending those to the 6600/6630, with no luck. All they do is display the files as raw text.
Is there any way of transferring the SMS messages from the T610 to a Series 60 device, or getting the new phones to recognise the .CSV/.XML/.HTML formatted lists of messages?
Any help much appreciated
In your T610, move your SMS to "SIM Archive", pop your SIM card into 6600/6630 and to go Messaging and select SIM Directory. Maybe you would like to move those SMS from your SIM card into your 6600/6630
