N7610 problems! Can't receive and send out calls :(
1 replies · 2,138 views · Started 12 January 2005
Hi I just got my N7610 around 2 weeks back, everything was great. Then suddenly I couldn't make calls and I tried calling my fone but it doens't ring, there's just a "beep beep" sound. Same thing with MMS, it used to work fine but now it doesn't even send, after a few seconds of sending the mms, the fone will reboot by itself, just like when you try to make a call, after dialling it will hang and reboot. I tried to upgrade to the latest firmware, even did it twice, but to no avail.. the funny thing is my SMS still works fine. I haven't even installed any applications, just moved some pictures and soundclips from my PC, I haven't dropped it nor have it gotten it wet...Has anybody experienced this problem before? I think it might be a hardware/factory defect problem... 😞
Is there a little 2 on the mian screen??
If there is just hold down the # key for about 10 secs and it will ask to switch lines push yes and it should sort the problem out!!!
