Can anyone help me ,I have installed something on my memory card and now it is corrupted I have tried fe xplorer but shows nothing in drive e,Tried tuning the phone off and taking memory card out and put back in,Still says memory card corrupted is there no way of fixing this?
Memory Card
I Have The Same Problem. I Tryied Also to format it from the Computer with no Luck.
I've already made A Thread But No one replyied me
have you tried re formatting the card? this should work although u will lose all data on it
Yes i have done that it still says memory card corrupted
daywalker wrote:have you tried re formatting the card? this should work although u will lose all data on it
If It Is Corrupted u Can't Format It also From The Computer
I'll Bring My phone to the Nokia center and they'll change my card
Well i think that there's A solution : The Firmware update; I Talked with the owner of the shop where i bought it and he said that the Nokia Centre told him that Firmware Update will fix this Bug
I donno when he will update my phone i'll tell u if this fix the Problem
Now im pissed off !!!!!! Just bought another memory card and it s done the same thing after one day . Saying memory card is corupted. I will need to take the phone back to vodaphone.
I'm Going to Upgrade The Firmware Version .......
I see you have had the 6600 and now the 6630
i have had neither but want the 6630 - the only thing is i want to install tom tom mobile on it which i know runs on the 6600 with a 128 card- but i am desperate to find out if it runs on the 6630
is it true the mmc slot is smaller on the 6630 and if so can you think of a way it would work?
someone on this site has achieved it.
RWP wrote:I see you have had the 6600 and now the 6630i have had neither but want the 6630 - the only thing is i want to install tom tom mobile on it which i know runs on the 6600 with a 128 card- but i am desperate to find out if it runs on the 6630
although i have not got tom tom software i understand that it does work on the 6630,however the 6630 uses the reduced size mmc card & currently the max size of 6630 DV RS-MMCs is 65mb and the 6600 has the older larger type card so cannot be swapped.
As a guess you should be able to transfer the app to yr phones memory via cable or bluetooth but u may have a problem if it takes up alot of yr phone memory.
have a look here http://flash.atpinc.com/company/news.php i think the co is about to release larger cap rs mem cards which may work on 6630.
hope this helps
