6630 as Webcam: Remote S60 and USB Data Cable - A possibility?
1 replies · 11,367 views · Started 12 January 2005
Hi guys - just got my 6630 phone, and I am wondering if I can use it as a webcam in my normal PC applications (e.g. MSN/Yahoo Messenger) with a USB Data Cable? In other words -- 6630 as a webcam without having to have a Bluetooth (or serial cable) connection with the PC.
I tried Remote S60, but apparently it does not support the USB Data Cable - has anyone tried/managed to get it to work in spite of this apparent restriction?
I know that a similar thread exists in another thread, but just thought of giving it a try here too.
-- Irfy
Irfy wrote:Hi guys - just got my 6630 phone, and I am wondering if I can use it as a webcam in my normal PC applications (e.g. MSN/Yahoo Messenger) with a USB Data Cable? In other words -- 6630 as a webcam without having to have a Bluetooth (or serial cable) connection with the PC.
-- Irfy
:icon13: I've try the same but "Serial/COMx: for maximum speed using an emulated Bluetooth Serial or IrCOMM COMx port" is it bluetooth on serial port or a blue tooth on usb "serail port?" ?
The direct pop-port usb cable on N6630 doesnt work with remote s60 ?
Perhaps a patch will be launched, let's wait a little?
usb2.0 is 240Mbps speed but I think direct cable connection is faster than usb blootooth , Irfy do you have any idea about this?
thx. 😎
