After having one between 1-2 months and discovering loads of problems with it, they've now gone away or I have found somple workarounds. ![]()
Eg, my problem with the PC Suite app that I thought may mean I'd have to lump for a firmware upgrade, was solved by removing all related files from my PC and re-installing. Then in future making sure I never disconnect my phone without shutting down my PC first (silly I know, but it works, the problem hasn't re-occured).
Unfortunately there are some I can't fix such as the delayed beep, but it seems the longer I have the thing the more stable it becomes. The only time I need to reboot now is when I take screenshots of my skins ![]()
Anyway I was wondering after all the recent posts outlining bugs, has anyone else managed solve their problems after a little work, or given up at the first hurdle?
BTW - Rafe, hopefully this post may generate some useful info for the Userguide ![]()
Flipside
