hi all
first of all sorry for my bad english.
i got a problem,
i had a 6600 and i installed al lot of k3wl tools. now i get the better phone 6630.
at first i wanna install FEEXPLORER to check whats up on my phone. but now i get a info at my NOKIA APPLICATION INSTALLER when i wanna install tools.
the message looks in my language:
Sicherheitsfehler bei Installation. Kann nicht Installiert werden.
in english it translatet it means
SECURITY ERROR AT INSTALLATION. CANT INSTALL. 😮
did any1 get same failures? any1 knows a way to install this software? isnt it the same symbian version like 6600? :con?
plz help me
b�regards
xcess :frown:
try this.
goto menu, tools then open manager
once its open select options and select settings, make sure software installation is on, online certif. check is off.
thats how mine are and ive never had any trouble installing any programs
wow! :icon14:
thx a lot! it will works! :tongue:
very nice new things my 6630 get in menues ^^ 😃
thx 😊)
now im very happy to install my appz
What is FEexplorer ? & Where can I d/l it ?
Thanks.......... 😊
error wrote:Hi,What is FEexplorer ? & Where can I d/l it ?
Thanks.......... 😊
ist a browser like the normal windows explorer for ur phone
take a look on this link --> http://www.allaboutsymbian.com/features/viewarticle.php?id=67
