Problem phone format number
0 replies · 2,618 views · Started 13 January 2005
have sucessfully sych my 6630 with outlook 2003. I have only one problem. Outlook 2003 stores the phone number in the following format +123 (456) 7890123 x ext. 1234
The synch works well and the number is copied properly to the 6630, however when i make a call the number called is +12345678901231234 (the ext. is attached to the phone number). Is that correct? is a bug? any suggestion.
Thank you
