Suite upgrade from 2.4.1 to 3.1.1
3 replies · 1,599 views · Started 13 January 2005
Hello, I have a P800 and a new XP pc. I have 2.4.1 and all the earlier versions of the PC Suite and can install the Suite upto 2.4.1 (installing one after the other).
If I want to upgrade to the latest Suite 3.1.1 then can I simply ONLY install 3.1.1 (without any of the previous versions) ?
If not then from where can I get all the versions between 2.4.1 & 3.1.1?
Thanks.
Delta737 wrote:You can just download 3.1.1, it's not just an update, it's a full version
Thanks. but it says on the website that it is NOT a full version but an upgrade package for the earlier 3.0. However, judging from the file size (35Mb) it does look like a full version.
Has anyone already done this? Please let me know your expirence.
Thanks.
Trust me, it is a full version. I upgraded a couple of times already (with the other version uninstalled first)
