[USB DC 3-WAY Plug Adapter] � Universal DC plug fits for 2.5 mm / 3.5 mm / 4.0 mm
- 3 universal DC Plug sizes
- Plugs into most electronics jacks (requiring input less than 5.6V / 800mA)
- Serves many charging purposes
- Easy to use
[ JAVOCharger (Car)] - A USB Car Charger Adapter that is sturdy, lightweight and compact
- USB Car Charger Adapter Voltage Input - 12-24Vdc / Voltage Output - 5.2Vdc, 850mAH
- Safely and speedily charges your device
- Plug in any car's cigarette lighter for power (Fits in any car, boat, or RV lighter)
- Easily portable - if you forget to charge your device at home, Javoedge's USB Car Charger is there to give your device's battery a boost.
[ JAVOCharger (Wall)] - A USB Travel Charger Adapter that is sturdy, lightweight and compact
- USB Travel Charger Adapter Voltage Input - 12-24Vdc / Voltage Output - 5.2Vdc, 850mAH
- Easily portable - Eliminates the need to travel with your device's recharging cradle
[ USB Extension Retractable Cable ] - USB Type A Male to Type B Female extension cable
- Multi-usages
- Extends the USB Bus Signal
- Works together with Standard USB Cables or USB DC Plug Adapter
- Cable must be plugged directly into a USB Port.
- Sturdy and high quality cable
$48.75
Click here for more information
USB DC 3-Way Adapter plus USB Extension Cable
Key Features
- Universal USB DC Plug in 3 sizes for different device requirements - Perfect for charging device with 2.5mm, 3.5mm, 4.0mm DC plugs such as Bluetooth Headsets, Cell Phones, Digital Cameras, PDA, and Portable devices.
- 5 feet (153cm) USB Extension Cable (AM-AF) � Also great for extending USB devices such as printers, modems, scanners, digital cameras, etc..
- Great traveling Kit & rolls up with a Velcro Strap for easy storage
- Easy to use and works with all compatible JAVOSync cables
