I used the Nokia Multimedia PLayer software that comes with the PC Suite to convert MPG to 3GP file but notice that the conversion length is only 10 seconds.
what options should i set to make the it convert the whole clip?
BT
BT
What version of PC Suite did it come with? I think this was a problem with some version in PC Suite 6.2. Get PC Suite 6.41 from http://www.nokia.com/pcsuite and the Multimedia Player in that.
@Limbt
are you talking about Nokia Multimedia Converter 2.0? I searched for this on google and eventually downloaded it from the Nokia web site and I can use it to create 3GP files from AVI files. Qulaity is not as good as PVAuthor but it is free unlike PVAuthor.
