First of all Id like to say hello to everyone on this forum, Ive just got myself a 7650 and just like everyone else will need help with it so when i came accross the great forum i thought id join up and what a great forum it is for 7650 owners 😃 so i hope i can be of any use to you all as all of you will be to me !
ok now some help im needing !!
first of all ive installed the t-mobile video thing and a few games on my phone how the hell do i uninstall them ???
also are there any programs like logomanager on the pc that i can use to edit my contacts ???
I'll thank you in advance
A big WELCOME from the 7650 forum. 😃
Ok to uninstall apps you can do that by going to:
Tools/Manager/choosing the app you want to delete/options/remove.
Easy as that.
As for the logo manager I'm affraid I can't help you there, but I'm sure someone else will.
J2theIZZO.
Cheers J2theIZZO that did the job got rid of those programs at last !!!
been ripping my hair out the last 2 days trying to get them off thats not the way it tells you in the manual !!
Doesn't it?, Another one for the FAQ then 😊
i think nokia sould sell the 7650 without the manual
it's just taking space and adding weight to the box and it has nothing to do with -USING YOU NEW 7650-
Logomanager does not work with Symbian phones! We have contacted them but they are not sure if they ever going to support Series60 devices!
😃 A big welcome to marky_2001uk too!!! There are many information and stuffs in here. Do make a search for any topic or information you may need. May you enjoy your stay with us
[quote="marky_2001uk"]First of all Id like to say hello to everyone on this forum, Ive just got myself a 7650 and just like everyone else will need help with it so when i came accross the great forum i thought id join up and what a great forum it is for 7650 owners 😃 so i hope i can be of any use to you all as all of you will be to me !
I'll thank you in advance[/quote]
why would you want logomanger when you can have seleq get this program you change your logos anytime with this little love.
I think that he wanted logomanager to edit his contacts and not for Logos! I think 😃
The BEST contact manager for Nokia phones is (I think) Oxygen Phone Manager from http://www.oxygensoftware.com - They do NOT currently support the 7650 yet (although Im sure they will soon) but the sites worth a look! 😊
[quote="thelagermonster"]why would you want logomanger when you can have seleq get this program you change your logos anytime with this little love.[/quote]
im looking for a program so i can edit the phonebook on the pc instead of the phone, Logomanager was just an example as i was using this program for all my other nokia phones, I dont want to edit logo's im just wanting a phone book editor 😃
Try using Outlook ... that is what it was designed for.
[quote="erhum"]Try using Outlook ... that is what it was designed for.[/quote]
what for editing the phonebook on a 7650 ??
I guess 'erhum' meant you can synchronize your contacts with outlook, hence create and edit your contacts there and synchronize using the Nokia PC Suite.
Does that help ?
U R Right ... for some reason that is what I had assumed you were getting at.
