hi all,
currently i just installed a new application for screen saver from psiloc, but seem
like not working at all..i just cant open the application..please help.. 😡
hi all,
Try this !
Menu>>>
Tools>>>
Manager>>>
Data Transfer>>>
Settings>>>
Then:
Turn the Software installation to ON>>> Turn the Online cert check to OFF....
That's it :icon14:
A lot of Psilocs software does not work on the 6630, the apps I have tried so far just show their "common security" software protection screen and then exits. If the same is happening to you, check their website for updates and contact support. I am interested in ListMan and they haven't yet updated that to make it 6630 compatible.
celios wrote:A lot of Psilocs software does not work on the 6630, the apps I have tried so far just show their "common security" software protection screen and then exits. If the same is happening to you, check their website for updates and contact support. I am interested in ListMan and they haven't yet updated that to make it 6630 compatible.
ya mine just same like u..just saw the 'common security' after that exit...but i already download their latest one for N6630 and still cant open it... :con?
