Can someone recommend me an in car holder?
4 replies · 3,141 views · Started 14 January 2005
I am just about to set myself up with a gps system and was looking for something to place my phone in the car so it is visable from the driving position. I have a krussel case, so I bought the multidapt car holder for it, then I found out that my car (vauxhall vectra) does not have any flat surfaces where it can be mounted and be visable/not obstruct anything else.
I usually get nokia branded accesories, but looking at the holder for the 6600, that needs a flat surface too.
Is there anything that has an 'arm' type attachment or will fit to an air vent?
Thats the one I was talking about, it looks like it will need a flat surface too. Any idea on how it attaches?
lakeywhite wrote:Thats the one I was talking about, it looks like it will need a flat surface too. Any idea on how it attaches?
Does this help ?
Thanks for that, but that is a flat bracket, my dashboard is all curves and not much free space to screw into really.
I have found a suction mount flexible arm that willfix to the windscreen, but that might be more irritating as I will constantly be aware of the suction cup in my field of vision.
:frown:
