ANSWERING MACHINE For SX1
4 replies · 3,019 views · Started 15 January 2005
Dear,
Does anyone know an "ANSWERING MACHINE" Software for SX1?
MTIT Answering Machine & Avista Answering Machine aren't compatible with SX1.
Thanks.
Yes, there is an answering machine software for SX1. It's Smart Answer from Symbianware. Make sure you get version 2.00 as 2.03 doesn't work with SX1.
ocujos wrote:Yes, there is an answering machine software for SX1. It's Smart Answer from Symbianware. Make sure you get version 2.00 as 2.03 doesn't work with SX1.
Thanks a lot.
memarian wrote:Dear,
Thanks.
Try to look for version 1.2 of that MTIT application - I've got it working fine on my SX1.
And as for v2.03 of the other one, I didn't realise; explains the failures I had with it.
clonmult wrote:Try to look for version 1.2 of that MTIT application - I've got it working fine on my SX1.
Dear
I find the Smart Answer V2.00 and it works excellent.
(But V2.03 doesn't work.)
Thanks for your help.
