Question to psiLOC:chapture 2:the soft version ;)
0 replies · 1,260 views · Started 21 October 2002
Dear programmer from psiloc out there,
how do i deinstall the parts of screensaver?
I ask,because i had some troubels with the alarm-enha.
if i was try to remove world-clock prof(new beta).
first i remove world-clock himself,
after that: PsiNT eLIB
-PsiNT helper....and if i tried to remove the Alarm enha. it doesnt works.
(but i fix it with a sync.and it dissapears from self,
if it have a connection to the pc-suite...)
After that i removed the world-clock pro. of my friends phone:
first alarm-enha.then world-clock pro and at least the:PsiNT eLIB(what remove auto.the helper.
(it will ask u allways:
u really wanna remove it,and that maybe other prog.not will work if remove.
This is first time a prog.from psiloc ask this:
normaly it removes the help-adds.from self:
maybe because this is a beta-version?)
My question now is:
How i must remove e-profile,if i want the forthcomming full-version of the new beta?
if is there a different like u tell me in the hard-version-threat 😉,
can i only install the new version up on the old,or must the beta first be removed?
At least:when comes out the full-version of e-profiles in the same version like the new beta is?
And is the Task-manager stabil yet???
cause i wanna take those progys,but i need my phone to betatest for epocware and others(and even for private fun :P )
and will not have the time and money to have another one soonly,if something will crashed down.
(This progys u write,all worke hardly in z,what make the features possibel,but also make it not real stabil.
its more save with progys they are in c)
thanX in advance for your answer
best regards
a enduser
S�mi
