7710 Abnormal Reboot
3 replies · 2,295 views · Started 16 January 2005
Hi guys,
I would like to know if anyone experienced the same problem. While composing a sms with the onscreen keyboard, try tapping on the characters as fast as you can while you compose.
Does your phone abnormally reboots when you do that? Mine does, but the sms is saved into Drafts and there is no data lost. 😊
I have more then 200 Contacts and i face this problem when i am managing contact like when i edit. But this problem occur less till now 3 times.
Phone reboot it self and then again start
The thing which is comman is that we don't loss and data.
well i am not having any such problems, i have 600+ contacts and 100+ messages. Yes, it hanged while playing soe 3gp file but i removed them and now everything is fine. 😊
phns i hv ownd:
SE t610, k700i, s700i, p900 & p910i
NOKIA 6610 3200 7250 3660 6600 6230 7610 6630 & 7710 whch i nw hv
thr aint a single phn out of all these tht ddnt re-boot abnrmlly, so relax
evn aftr frmware upgrades phns re-boot at will
in time as our fingrs get used 2 d keypad v tend 2 key in commnds real fast whch causes a re-boot
tips:
1.go easy on d keys, especially whn usng gprs & bt
2.avoid usng gprs & chngng thms whn d phn is chargng
3.delete a file tht causes a re-boot immediately
