Email
1 replies · 1,191 views · Started 21 October 2002
G'day All,
I can't get my emails to delete off my phone or server help please!
Also I have been able to receive emails but sending them has been a major drama it took me over 48 hours to send some then it wouldn't work again no settings changes were made.
Optus Ausrtalia network
The email thingy works slight different from normal emailer in PC. If you delete a email msg in your phone (Phone Only ) or (Phone and Server ), you are delete the msg body (contain the main msg) and not the header. If you wish to delete both, you choose Phone and Server. Once you select it, it will delete the body only and will delete both header and body when you connect to your mailbox online the next time when you online.
Don't worry about it, nothing wrong with thy phone, mate.
Just remember, if you choose delete from phone and server, it's mean delete everything and will not be able to get the msg back again ( work the same as you delete to trash bin in your mail, example: Hotmail's trash bin ) Hope that's answer your question
