system corrupted ?
3 replies · 1,475 views · Started 16 January 2005
hello dear friends
I am new in the forum and have a new 9500 😊
but trying to open the web Nokia.com with my 9500 a get the message ''system corrupted and ''program closed program :Web Reason code :ViewSrv Reason number :9 '' :con?
what are all these messages and why a got this message and I cannot open the Nokia.com ????
Hello and welcome Megalos
Can you say a bit more about the connections; were you using GPRS/EDGE or WiFi?
Megalos
I have seen a similar error with WiFi where the WiFi provider (hotspot provider) used a pop-up window to start the connection. My Opera browser was not being recognised. I think for you, you should turn-off the phone and remove the battery (this forces a reset). Try this procedure.
Also are you sure your GPRS is set-up properly as a Internet Access point? Best to test it with the email application.
Good luck
