Sebding E-mail from A925
9 replies · 1,949 views · Started 16 January 2005
I don't know how to, and whether it is a all possible, setup my A925 to send E-mails. I set up my E-mail account and internet account. I can receive my messages, but I can't send any. Do I need an E-mail client or is ti possible to do it with the phone itself.
My frimware version is: 3080.20.
@Szadzik, as long as your A925 is unlocked from the Three network you should be able to send/receive email using the Messaging app. Remember the SMTP server will be that for your network provider. For exmaple. my network is O2 therefore the SMTP is smtp.o2.co.uk
jah wrote:@Szadzik, as long as your A925 is unlocked from the Three network you should be able to send/receive email using the Messaging app. Remember the SMTP server will be that for your network provider. For exmaple. my network is O2 therefore the SMTP is smtp.o2.co.uk
Depending on what mailserver he's using, it isn't even necessary to unlock the phone. I was using my own mailserver when my A925 was locked without any problems.
I agree that there is an option of setting up an smtp server, all servers (smtp) I'm using however, require logging in with a username and password, there is no such option for smtp server in A925.
Szadzik wrote:I agree that there is an option of setting up an smtp server, all servers (smtp) I'm using however, require logging in with a username and password, there is no such option for smtp server in A925.
Yes, that's correct. The built in e-mail client does not support logging in to SMTP servers. Unlocking the phone won't help. Perhaps ProfiMail works. Beware though that it's not free, and I haven't tried it so I don't know if it supports what you're looking for.
hi !
the problem is that some email-providers (yahoo for example)
has a smtp-server that requires "smtp-authentication" which the standard email-program doesn�t support.
use profimail, i has "smtp-auth..." , then you can use yahoo for example
scannerman wrote:hi !
Yes, I believe I mentioned that. Yesterday. 😊
hi !
albatorsk: yes you did, but:
1. i wasn�t sure that you were meaning the same thing,
so i wanted to explaine the problem (smtp-authentication)
2. as you said "Perhaps ProfiMail works. Beware though that it's not free, and I haven't tried it so I don't know if it supports what you're looking for.",
i just wanted to confirm that it works, at least with yahoo...
Thanks guys, I really appreciate your professional advice, I'll try the program and report my discoveries.
Oh gosh, it's really nice app, profimail I mean. Once again thanks guys. It's realy nice looking and works fine.
