can someone help me urgent..
A call all users of 7610, can you RECEVE MMS masseges?
i have problem reseving mms. and automatic settings on my 7610.
i contact my provider VIPNET croatia, they get me new firmware v 4.0437.4 15-9-04, but i cant receve masseges again.
If you are using mms on 7610, can you tell me what is my problem,,
when i receving mms, i see that massege is coming. but it cannot dome i stops after some time..
help please.. urgent.
goto menu>messaging>settings>MMS> check if u have set it to 'on receiving message to retirieve immediately' and multimedia reception settings to what u like i have it to 'only in home network' i am not in ur country but i also could not receive multimedia messages until i did this, also in ur connection settings set GPRS to when available!
zainman wrote:goto menu>messaging>settings>MMS> check if u have set it to 'on receiving message to retirieve immediately' and multimedia reception settings to what u like i have it to 'only in home network' i am not in ur country but i also could not receive multimedia messages until i did this, also in ur connection settings set GPRS to when available!
tnx for answer but everything is set correctly, i checked whit my operator too
i think it's maybe my phone bed,or brokens? is it possible,, everthing is working just fine exept this. i have newest sotftware because i was to service 2 days ago and they "fixed" that, but it seems that its not correct.
help
If you can recieve SMS and do GPRS then the phone is not broken. You have a setting incorrect somewhere. Go over it carefully with a CS rep from your provider.
silkshadow wrote:If you can recieve SMS and do GPRS then the phone is not broken. You have a setting incorrect somewhere. Go over it carefully with a CS rep from your provider.
done that. but still cant MMS. now my phone is in service..
