Has anyone else experienced a Microsoft Cisual C++ Run-time Library error during loading of the PC Suite v6.41?
The result of this error is that a connection cannot be established with the 9300.
Details are:
PC Suite 6.41 running on Windows XP SP2
Right at the end of loading the following message is displayed:
Microsoft Visual C++ Run-time Library
Program
C:\PROGRA~1\COMMON~1\PCSuite\Services\Service~1.EXE
R6025
- pure virtual function call
The prigram that is failing appears to be
ServiceLayer.exe v6.41.20.0 16Nov04 11:55
Once failed the phone will not connect to the PC.
If I check Connection Manager, none of the connection types are selected even though previously Infrar Red and USB (DKU-2) were checked.
If I try and select USB, the Connection Manager just hangs.
Any Help appreciated. Also any suggestion where I formally submit this bug?
