What is the best? (I think the second one)
Has anyone tested both images editors?
BTW, Digia link is www.digia.com
I just tried it! Damn I think it�s the best!
If you liked Photo Editor, then try Image Plus!
BTW, I downloaded the trial version from www.my-symbian.com
Ciao manowar,
Why you like it more than Photo Editor ? Did you check the new version of PE with resizing of clipart really fast and selection of fonts ? Anyway both apps are really similar....
Ciao RobyOne from Bitween 😊
Yeah, both apps are similar... But I prefer to see the image "at once", not "zoomed", and can set frames over the whole of the image, not only over one part of the image (perhaps this is an error of mine). And I think that the text styles are more friendly in ImagePlus... I don�t know... Anyway thanks for your information about the new version of PE! I�ll try it! 😉
Best regards!
