using gprs
1 replies · 1,801 views · Started 17 January 2005
hi i just bought a nokia 6260 and i couldnt get to use the net on it. i manage to connect to the net but then no page downloads? basically i wanted to download more themes and stuff but arent managing to do it? any thoughts? much appreciated.
Make sure you have subscription/plan that allows either WAP or full Internet access, or preferrably both.
Then make sure your operator/service provider/carrier has it enabled (provisioned) on their systems, too.
After that, make sure you have received the operator's MMS, WAP and Internet access point settings (from their web page, by calling their customer service, or whatever, if they're not preinstalled).
Then make sure that the WAP or Internet access point is defined for the browser as default (or specifically for a bookmark of yours, if you want to use a different access point than the default one).
