A friend on another forum shared this with us & I think people on here will benefit from it to.
Bluetooth Enhancer.
Basically it allows more than one BT connection to the phone, so far I have managed to have my GPS unit and headset working at the same time.
I have written some instructions on how I paired both units as so far I am yet to find any other information on the app.
What I have done is this :-
1. Do not have the phone BT settings set to authorised on the connections, leave it so you have to say yes or no.
2. Turn on your GPS unit for instance then open up the BT Extender from your menu and choose Discover Devices. It should come up with a list of BT devices, I only have one on at present to thats all that comes up, in this case TomTom Wireless GPS.
3. Now Click back which appears to exit BT Extender. Then start your GPS Navigation or BlueSky etc. and within that app connect to your GPS unit.
4. Open BT Extender once more & choose Options Start Slave, it will show waiting for connection.
Now turn on your (in my case) BT Headset. The phone will ask if you want to accept the connection, choose yes.
If all goes well your Headset will beep and you'll be running two bluetooth connections at the same time.
It isn't a dead simple process as there is no staright option to connect to this unit and this unit, you have to do it in a certain sequence for it to work. But it can be done with time and patience, I am still getting in wrong now. I wrote some instructions and had to go back and re-write them again
This little application shows to us that the ability is there, it just isn't implemented in the firmware.
Come on Nokia, wake up!!!!
i have the application but i dont know if i should upload it.. maybe it is a crack.. a friend gave it to me, it has been tried with the 7610 also.. if a moderator will give me the green light then i will be happy to upload the application 😊
