format 7650
15 replies · 2,623 views · Started 21 October 2002
does anyone know how to format the device
without any 3rd party software ?
i need to free some memory space quickly.
and i don't have enough space to install new program that can do it for me.
thanks !
Well u can do two things!
One is uninstall all your software and
two type in *#7370# and erase ALL your data (programs and contacts)!
thanks, the *#7370# really did it.
do u know more codes like that ?
and how did u learn about that (if i can ask).
rp
You learn them here, in the forums! You cannot believe the amout of information this web site has! Everything I know about this phone comes from here! 😃
he is right. Thanks for stay tune with us in this Almighty forum
Hehold.....MaleBuffy the Honoured Forum Elder!!!! Haill to all users!!!
:P
Honoured forum elder! pah......Mr 7650 😃 8) 😃
Malebuffy, I thought you were taking a break? I knew that wouldn't last long 😃
😮ops: Did you? 😮ops:
I've been away all weekend too (In the pub), I try and visit from the pub but there's only so much you can do on a 7650 screen after 10 pints and a bottle of sambuca. 😃
Ok, moving back on topic 😉
Does the format code delete all settings for alla programs too? Even if i uninstall my IM+ and then do a re-install it remembers my icq# and pass, do they all dissappear when using *#7370#?
best is,first remove all Java/Sis/Midi/Wav/Fotos/mp4.etc
Then be shure,that the batterie is full...
Then it sould work ok.
S�mi
[quote="mikeprice53"]or in my case not reboot at all ! :roll:[/quote]
Did you wait long enough? It takes 1-5 minutes to format, when formatting there is just Nokia text in screen. If you stop formatting (take battery off), you might get contact service text in screen and there is not much to do yourself 😞
