I am wondering weather to get this phone (or the 6260). I have heard that the numeral keypad is a little small. I was wondering would you recommend this phone, thanks in advance.
6670
if u want more business then style, then get this, otherwise i would recommend the 7610. not the 6260, i personally think that its difficult to use becasue the menu keys are on the flap thingy.. and it doesnt have a megapixel camera like that 7610 and 6670, goto nokia.com for a detailed comparison..
i went for the 6670 cos i didn't like the swervy keyboard on the 7610, the phone is lovely to use and i don't think the keys are especially small - suppose it all depends on how chunky your fingers are 😃 i have nails just over an inch long :wink: (from cuticle to tip) and i have no problem using this phone.
The phone is GREAT just have it for 2 days and I LOVE it :icon14: :icon14:
i have had most of nokis symbian range and i must say that the most important factor betweeen todays choices is the look.
and the 7610 wins hands down. but then it all depends on personal choice.
Keypad for 6670 is small. Esp when doing keypad lock hard to press *(the smallest key on the bottom left with low light also). Overall is good.
For 7610, '3' button is sometimes hard to press. Must upgrade ur software to the latest ver, if not the phone is buggy.
Depends on style(7610) or function(6670).
Also 6670 is thicker than the 7610.
i just bought mine 3 days ago, and it works great, its soooooo nice, i just love it!!!
