Problem uninstalling JJL Keylock
3 replies · 3,733 views · Started 19 January 2005
Hi Everyone, I recently received my 6600 and installed JJL Keylock on my MMC. I went to remove the program using app manager and it says removing for just a second then goes back to the top of the list and the programs (JJLKeylock and JJL Common Library) are still there. Can anyone tell me what files to remove using FExplorer or if anyone else has had a similar problem when uninstalling that program. Thanks for the help, BB
just go to the drive that u have installed JJ keylock to, then system>apps> and delete the whole folder that says 'JJ keylock' and the app would have been removed 😊
