6630 + Jabra BT800 problem?
7 replies · 2,832 views · Started 19 January 2005
I have a Nokia 6630 and using the Jabra BT800 Bluetooth headset , now i have this problem that the person that im calling hears a klicking noise once a second, anyone else that can confirm this? or how to solve it?
(iv'e tried the headset with a Nokia 6650 and it works perfect so its not the headset itself.)
Thanx
Doggen wrote:I have a Nokia 6630 and using the Jabra BT800 Bluetooth headset , now i have this problem that the person that im calling hears a klicking noise once a second, anyone else that can confirm this? or how to solve it?
Thanx
does the caller ID display the name and number on the BT800? or is it only the numbers?
sorry cant help you with your problem. where did you get it from?
mplayer74 wrote:does the caller ID display the name and number on the BT800? or is it only the numbers?
I have nokia 6630 and jabra BT800 and the problems are:
- doesn't display caller number
- doesn't ring
Other stuff works O.K.
andy6630 wrote:I have nokia 6630 and jabra BT800 and the problems are:
- doesn't ring
doesnt display number? i read on howardforums.com that it displayed the number on the caller ID when paired with a Nokia...though it didn't specify which Nokia.
anyways, i wont be getting it unless it displays the NAMES on the called ID
Doggen wrote:it was my headset that was faulty , it works perfect now....thanx all
how good is the bt800 ive got a hdw4 it very quit or im def
so did you get it replaced? and does it display names on the called ID?
I purchased a BT800 and had exactly the same problem. The other party could hear a clicking noise every second (or more) and it was very annoying as it was loud.
As per the above, this ONLY happened with the 6630 and not my other 2 handsets that I tried.
I got the BT800 swapped and the new one does not have this problem. I wonder if its a Bluetooth 1.2 fault with some BT800s, because thats the only difference about the 6630 compared to my other handsets.
The BT800 does NOT display names with the Nokia 6630, only numbers. It DOES display names with an Sony Ericsson Z600.
Jonathan
