Nokia's clock alarm for Series60 doesn't allow specification of different sound files for the alarm - just really uneffective beep. Is there a program that allows this sort of option?
Thanks.
Thanks.
Yes try smartprofiles by symbianware.com or extended profiles by psiloc.com here u can change the tone of ur alarmz
Thanks for the info. Now I'm a peppier puppy.
try also worldclock pro for multiple alarms and u can change also the alarm tone here, worldclock pro by psiloc
Pepper Puppy wrote:Thanks for the info. Now I'm a peppier puppy.
Pepper Puppy wrote:Nokia's clock alarm for Series60 doesn't allow specification of different sound files for the alarm - just really uneffective beep. Is there a program that allows this sort of option?Thanks.
Not sure about the old Sym6.1 series but the 6600 and certainly everysymbian ive had after that lets you specify the clock tone by going to Clock > Options > Settings > Clock Alarm Tone
Ditto with Calender Alarms
Well the programs are cool the only thing bad is running them make the phone running memory less and installing different programs make the phone error occurance more frequnet.
Anywyz is there any software which can change tones in Nokia mobile like samsung has on keypad lock or keypad tones.
